settings on permanent?
latenight101
Post by latenight101 »
Hi folks - I bought basic version of SM 2018 and love it but a few mysteries. I find that I have to keep turning Show Tooltips setting off every time I start the program. Is there no way to make settings stick permanently? Seems like there should be some config file somewhere that saves that sort of thing, like Word does. Thanks in advance.
Re: settings on permanent?
Thanks for reporting this problem. I was able to reproduce it and forwarded the details to our development team.
Please share ofw18config.ini and tmw18config.ini files from your Documents\SoftMaker\Settings folder.
Please check this problem again and if this problem is still there please share ofw18config.ini and tmw18config.ini files from your Documents\SoftMaker\Settings folder.
