Feature request - Paste Special(s) script command
americanaustralian
Post by americanaustralian »
Hmm...apparently there is no way to do a scripted Paste Special. I'm replicating a trailing stop tracking system for my stock portfolio (I have it set up and operating in MS Excel with VBA), and it absolutely requires the functionality of copying a column of cells and then pasting ONLY the values. In my opinion, not having this is a serious deficiency in BasicMaker. It would be nice to have all the Paste options available in BasicMaker scripts.
I can work around it by writing the values into a text file, then reading them back into my spreadsheet, but it would be much better if I could just do it "inside" BasicMaker without reference to any external file.
Re: Feature request - Paste Special(s) script command
Thanks for this suggestion. I have forwarded this request to our development team.
Meanwhile, there is a way to do it in BasicMaker. For this you have to follow these steps:
1. Open PlanMaker, Ribbon command File | Customize drop-down | Customize Ribbon.
2. In Quick Search type Paste unformatted text.
3. Select Paste unformatted text > Click on Shortcut keys.
4. Click in Text field Press new shortcut key > Press any new shortcut key, for example, Alt+V > Click on Add >Close this dialog.
5. Now you can use SendKey after selecting the desired destination to paste the copies range.
Try this below-mentioned test code after performing above steps:
Code: Select all
Sub Main
pm.Visible = True
pm.Activate
pm.Range("B5:E17").Copy
pm.Range("N5").select
SendKeys "%v"
pm.Range("N5:Q17").PasteSpecial
Set pm = Nothing
End Sub
americanaustralian
Thanks for the help, SuperTech. So, I tried exactly what you suggested. Here's the result:
If I step through the code (with the F8 key), execution stops on the "pm.Range("G2:G52").PasteSpecial" line, and gives "Error in line: 36 - Object doesn't support this property or method"
If I run the script with the F9 key, the actual Paste Special operation works as expected, but execution stops on the "pm.Range("G2:G52").PasteSpecial" line and gives the same error code
If comment out the "pm.Range("G2:G52").PasteSpecial" line and step through with the F8 key, nothing happens except the "G" column heading gets the focus...and if I use the F9 key, everything works fine, and the Paste Special succeeds.
Just remove this line, this was pasted by mistake. #-o I was doing some more testing and pasted this also. Just remove it and run the code.
Code: Select all
Sub Main
pm.Visible = True
pm.Activate
SendKeys "%v"
Set pm = Nothing
End Sub
americanaustralian
Checked the results of running this code (modified with my cell addresses, of course), and it doesn't work. Specifically, the %v command does nothing when the script runs, but using the command manually works as expected.
Strange, It's working fine here without any problem. Did you follow all steps? What shortcut key you created for "Paste unformatted text"?
When you are running this code, are you getting any error?
americanaustralian
Yes, it is strange. I don't get any errors at any time. If I run the code from PlanMaker with the Run Script ribbon command, the spreadsheet blinks momentarily as if something happened, but nothing gets updated. I tried the Run Script command both from the ribbon and the quick launch toolbar.
If I open BasicMaker and run the script using the F8 key to step through it, nothing works, no momentary blink, no update, no errors. If I run the script using the F9 key, the script runs as expected, but BasicMaker has to be open...I can see the cells being processed, and the update works. As you said, strange. Here's the code:
Dim pm As Object
Sub Main
pm.Visible = True
pm.Activate
' ***** Update the Trailing Stops worksheet *****
pm.Range("F3:F53").Copy
pm.Range("G3").Select
SendKeys "%v"
pm.Range("A1").Select
Set pm = Nothing
MsgBox "Trailing Stops Updated"
End Sub
Yes, when I ran this script from PlamMaker now, Sendkeys is not working. I reported this problem to our development team. Meanwhile, you can use this particular script from BasicMaker if required.
