Files Grow Larger And Larger Regardless Of Input Data
hwl.gmx
Post by hwl.gmx »
The same issue as posted here:
https://forum.softmaker.com/viewtopic.php?f=366&t=20035
As I stated in the reply in that thread:
A 5KB file grew to 2.5MB, there is no addition in the number of tables..only editing (updating) the same table over and over again.
It seems not much, only 2.5MB,,but what if I worked with hundreds of files?
I hope the fix is underway both for the new Office 2021 and the old 2018.
Regards,
HWL
Re: Files Grow Larger And Larger Regardless Of Input Data
Thanks for reporting this problem. Please share the associated file of PlanMaker with which you are getting this problem so that we can do further investigation for resolution.
https://forum.softmaker.com/viewtopic.p ... 323#p66323
