Heading inside Text frame not being detected in ToC
subhasiscgr
Post by subhasiscgr »
As the title says, heading inside text frame is not being picked up by ToC. The MS Office solution is to use a frame. But I do not know how to add a frame in Softmaker Office 2018. Does anyone have any idea?
Re: Heading inside Text frame not being detected in ToC
Thanks for reporting this problem. I was able to reproduce it and forwarded the details to our development team.
You can add Text Frame by Ribbon command Insert | Text Frame > Then draw the frame with the desired size.
