TextMaker - It does not respect formatting inside text frame
tausrd
Post by tausrd »
Dear all,
I create a text frame to put inside :
-a picture
-and message : Fig.XX.......
Inside the text frame, I centered both the picture and message. Then I save the document. Later, when I open the document : it is not centered...the formatting inside text frame is lost... ...an example is attached.
Please, I appreciate your help.
Best Regards,
Claudio
eje.tmdx
(98.12 KiB) Downloaded 5374 times
Re: TextMaker - It does not respect formatting inside text frame
I wasn't able to reproduce the issue. I'm sending a screenshot of what I get.
I opened your file, saved it as eje2.tmdx, closed it, and opened it again. It looked the same.
Could you please send us a screenshot and maybe tell me what I might have done wrong?
