Default file locations
Spinnekop
Post by Spinnekop »
Softmaker settings/templates/designs etc are in a directory under Documents. eg. E:\Documents\Softmaker\Settings
I want to change this directory to E:\Softmaker\Settings (and for the others) but am not sure what effect that will have. I can see how to change the directory for templates and backups but not the others.
Re: Default file locations
Please don't change this directory location as SoftMaker Office loads settings from this directory only. If you want you can store your documents, templates, backups, etc on different locations for which options are already available as you mentioned.
