TIL that you can run Windows 10 64-bit version on 1 GB RAM
farukhcasy2
Post by farukhcasy2 »
What I did was I installed the 64 bit windows 10 system on a normal machine with 8gb ram and than I took the ssd and put it inside my old laptop that has only 1gb ram and it booted normally. Ths speed was quite normal. It's interesting. I always thought that 2gb ram is minimum but today I saw that 1gb is enough as well.
Re: TIL that you can run Windows 10 64-bit version on 1 GB RAM
Thanks for your feedback. Yes, SoftMaker Office always provides the best efficient performance, full professional features and user-friendly interface even in lower system configuration.
