Why is this slower than Freeoffice?
subhasiscgr
Post by subhasiscgr »
Hi. I am a long time FreeOffice user. I finally bought the paid version in the recent sale. And the very first thing I noticed is that selecting/deleting text is very slow on certain documents. I uninstalled Softmaker Office 2018 and went back to FreeOffice 2018 (cuz it is not possible to keep both) and the lag disappeared. I tested with the same documents.
I am pretty sure certain formatting is causing this but figuring this out has been problematic.
I installed the demo on a fresh Win 10 VM to ensure that it is not my OS, and sure enough, it is slow on the VM as well.
Does anyone have any idea what to look for?
Re: Why is this slower than Freeoffice?
Please send us your TextMaker file on which you have this issue for investigation. If you would like to send it to us privately, please send us an e-mail to forum[at]softmaker.de
https://forum.softmaker.com/viewtopic.p ... 201#p65201
subhasiscgr
I stripped the document of everything until only the problem element remained: Autoshapes. For some reason this document uses autoshapes instead of text boxes. But I can not recreate this issue on a blank. And it is still blazing fast on FreeOffice.
Actions that are slow: Deleting, Selecting text using shift+arrow, Typing.
I attached the sample file. I converted it into a lorem ipsum document so it can be publicly shared.
debug.docx
(57.69 KiB) Downloaded 3109 times
I tried that given file with both FreeOffice and SoftMaker Professional 2018, I didn't find any difference in performance while working on them. Please share your sminfo file so that we can investigate this issue further. You can create it by clicking on '?' > About > 'Write system information...'
subhasiscgr
Code: Select all
SoftMaker TextMaker System Information
Revision: 974
Cpu(s): Intel(R) Core(TM) i7-4702MQ CPU @ 2.20GHz
Gpu(s): Intel(R) HD Graphics 4600
*** File info ***
[C:\Users\Subhasis\Documents\SoftMaker\Settings\tmwfo18config.ini]
[tmw]
HtmlClipPictures=C:\Users\Subhasis\AppData\Local\Temp\~tmw1\2b204646.tmp
WinSize=104,104,1129,629
Win32Info=free.32.974
AsianFonts=0
ArabicSupport=0
DefaultFormat=6
TimeFormat=
DateFormat=
SidebarRatioRight=-1073741824
SidebarPage=2386
SidebarAdPic=7
SidebarAdDate=06.04.2020
WSColorRGBValue=11250603
CheckExtension=111111111111000011100
NewProgWindow=1
FrameGrid=0
PageBorders=0
LanguageID=1033
BackupFilesPath=C:\Users\Subhasis\Documents\SoftMaker\Backup\
TmpPathGlobal=C:\Users\Subhasis\AppData\Local\Temp\~tmw1\
TmpPathLocal=C:\Users\Subhasis\Documents\SoftMaker\Settings\temp\
Handling=32
AdsLastDate=5.4.2020
FirstLaunch=6
PreviewPos2=357,510,0
Documents=C:\Users\Subhasis\Documents
Databases=C:\Users\Subhasis\Documents\SoftMaker\
Pictures=C:\Users\Subhasis\Documents\SoftMaker\
Macros=C:\Users\Subhasis\Documents\SoftMaker\
PdfFiles=C:\Users\Subhasis\Documents\
[tmw MRUFontlist]
Fontname0=Consolas
Fontname1=Times New Roman
Fontname2=Garamond
[tmw History]
RecentFilesPinned=0
HistoryFile0=0,0,E:\VM_SHARED\debug.docx
*** EOF ***
*** Startup log ***
[00031ms]: InitColors
[00031ms]: InitMouseWheel
[00031ms]: StartMain
[00031ms]: comInit: Ole2
[00031ms]: comInit: TmpSystemInit
[00031ms]: RibbonInit
[00047ms]: Dpi info: 96 ; 96 --- 96 ; 96 --- 96 ; 96 ; 96
[00047ms]: Dialog font final metrics info: (12) --- 7 ; 15 --- 7 ; 15
[00047ms]: comInit: CmdLine
[00047ms]: CmdLine <>
[00047ms]: comInit: OleAutomation
[00062ms]: comInit: Address
[00062ms]: comInit: DDE
[00062ms]: comInit: InitCountry
[00062ms]: Country Settings1: ID:1 CP:4e4 Lid:409 Curr:$ CF:0 NF:12 TS:, DS:.
[00062ms]: Country Settings2: MS:2 LS:, Lng:English
[00062ms]: Country Settings Date: DF:3f21 DS:/ DW:,  D1S:  D2S:,
[00062ms]: Country Settings Time: TF:0 TS:: TA:AM TP:PM
[00062ms]: comInit: InitComPrefs
[00062ms]: comInit: Install
[00062ms]: comInit: InitSpellcheck
[00078ms]: comInit: InitAppPrefs
[00078ms]: comInit: Controls
[00094ms]: comInit: Icons
[00094ms]: comInit: Res
[00094ms]: comInit: AppWindows
[00109ms]: comInit: Frame
[00109ms]: comInit: CreateFrameMenus
[00109ms]: comInit: CreateFrameWindow
[00109ms]: CreateWindowExSm <tmwMdiFrame>
[00109ms]: CreateWindowExSm <SMMDICLIENT>
[00109ms]: comInit: CreateFrameStrips
[00125ms]: CreateWindowExSm <SMCTLSTRIP>
[00125ms]: CreateWindowExSm <SM_SLIDERCTRL>
[00125ms]: CreateWindowExSm <SMCOMBOLB>
[00141ms]: CreateWindowExSm <SMCTLSTRIP>
[00156ms]: CreateWindowExSm <SMCTLSTRIP>
[00156ms]: CreateWindowExSm <SMCOMBOLB>
[00172ms]: CreateWindowExSm <SMCTLSTRIP>
[00187ms]: CreateWindowExSm <SMCTLSTRIP>
[00203ms]: CreateWindowExSm <SMCTLSTRIP>
[00203ms]: CreateWindowExSm <SMCOMBOLB>
[00219ms]: CreateWindowExSm <SMCTLSTRIP>
[00219ms]: CreateWindowExSm <SMCOMBOLB>
[00234ms]: CreateWindowExSm <SMCTLSTRIP>
[00234ms]: CreateWindowExSm <SMCOMBOLB>
[00250ms]: CreateWindowExSm <SMCTLSTRIP>
[00250ms]: CreateWindowExSm <SM_SLIDERCTRL>
[00266ms]: CreateWindowExSm <SMCTLSTRIP>
[00266ms]: CreateWindowExSm <SM_SLIDERCTRL>
[00266ms]: CreateWindowExSm <SMCOMBOLB>
[00266ms]: CreateWindowExSm <SMTOOLTIP>
[00266ms]: comInit: Colors
[00266ms]: comInit: ThemeSelect
[00266ms]: comInit: WindowSize
[00281ms]: CreateWindowExSm <SMRIBBONHEADER>
[00281ms]: comInit: Treeview
[00281ms]: comInit: Cursors
[00281ms]: comInit: AppBrushes
[00297ms]: comInit: AppFormat
[00297ms]: comInit: AppIcons
[00297ms]: comInit: AppBuffer
[00297ms]: comInit: BrushCache
[00297ms]: comInit: AppFonts
[00297ms]: comInit: AppLFile
[00312ms]: CreateWindowExSm <SMCOMBOLB>
[00328ms]: comInit: Accelerators
[00328ms]: comInit: History
[00328ms]: comInit: appData
[00328ms]: spInitCountryInfo(0): ID:1 Date:DMYhmsQ TS:, DS:.
[00328ms]: spInitCountryInfo(1): ID:1 Date:DMYhmsQ TS:, DS:.
[00344ms]: GetMRULanguages
[00344ms]: comInit: Printer
[00469ms]: comInit: QuickPath
[00469ms]: comInit: MAPI
[00469ms]: comInit: Speller
[00469ms]: comInit: Register
[00484ms]: comInit: ddeCmdList Start
[00484ms]: comInit: ddeCmdList End
[00484ms]: comInit: ShowWindow
[00516ms]: comInit: Timer
[00516ms]: comInit: appCmdList (non-null) Start
[00516ms]: comInit: appCmdList (non-null) End
[00516ms]: comInit: AutoLoad
[00516ms]: comInit: appCmdList (null) Start
[00516ms]: comInit: appOpenCommandList
[00531ms]: CreateWindowExSm <WP>
[00531ms]: CreateWindowExSm <WPCHILD>
[00547ms]: CreateWindowExSm <SMRULER>
[00547ms]: CreateWindowExSm <SMRTAB>
[00547ms]: CreateWindowExSm <SMVRULER>
[00547ms]: CreateWindowExSm <SCROLLBAR>
[00547ms]: CreateWindowExSm <SMSCROLLBAR>
[00547ms]: CreateWindowExSm <SMVERTBUTTONS>
[00547ms]: CreateWindowExSm <AWERESIZER>
[00547ms]: CreateWindowExSm <SIDEWND>
[00562ms]: CreateWindowExSm <UNICONTROL>
[00562ms]: CreateWindowExSm <SM_SEPARATOR>
[00578ms]: CreateWindowExSm <SM_OUTSCROLLAREA>
[00578ms]: CreateWindowExSm <SM_INSCROLLAREA>
[00578ms]: CreateWindowExSm <SM_SCROLLAREABUTTON>
[00578ms]: CreateWindowExSm <UNICONTROL>
[00578ms]: CreateWindowExSm <SM_HLINK>
[00578ms]: CreateWindowExSm <SM_BUTTON>
[00625ms]: LoadDocument <->
[00734ms]: CreateWindowExSm <SM_SLIDERCTRL>
[00859ms]: LoadDocument End
[00859ms]: comInit: appCmdList (null) End
[00859ms]: comInit: Address
[00859ms]: comInit: UpdateCheck
[00859ms]: System information startup log finished.
[00859ms]: comInit: Dispatch
[6751094ms]: Delayed AppData
[6751094ms]: ===============
[6751094ms]: Date 07.04.2020, 01:16
[6751094ms]: Windows 10.0, Build 18363 720
[6751094ms]: TextMaker free, Revision 974.0207 (32 Bit)
[6751094ms]:
[6751094ms]: Windows: C:\WINDOWS\system32 (32612 MBytes free)
[6751094ms]: Tempfiles: C:\Users\Subhasis\AppData\Local\Temp\ (32612 MBytes free)
[6751094ms]: TEMP: C:\Users\Subhasis\AppData\Local\Temp
[6751094ms]: TMP: C:\Users\Subhasis\AppData\Local\Temp
[6751094ms]: Application: D:\Program Files (x86)\SoftMaker FreeOffice 2018\TextMaker.exe (13732 MBytes free)
[6751094ms]: License: C:\ProgramData\SoftMaker\offree2018.lic 1720 bytes
[6751094ms]: Memory: 58/100 of 3613804 MBytes used
[6751094ms]: Screensize 1366x768
[6751094ms]: Printers:
[6751094ms]: Windows printer <SEC30CDA7ABCBED,winspool,Ne00:>
[6751094ms]: Printer <SEC30CDA7ABCBED,Samsung M267x 287x Series,http://192.168.1.211:8018/wsd>
[6751094ms]: Printer <OneNote,Microsoft Software Printer Driver,>
[6751094ms]: Printer <Microsoft XPS Document Writer,Microsoft XPS Document Writer v4,>
[6751094ms]: Printer <Foxit Reader PDF Printer,Foxit Reader PDF Printer Driver,>
[6751094ms]: Printer <FlexiPDF,ActMask,>
[6751094ms]: Printer <Fax,Microsoft Shared Fax Driver,>
[6751094ms]:
[6751094ms]: Resource files:
[6751094ms]: TextMaker_ar.dwr : 153782 bytes : [7.2.2020 3:13.48 GMT]
[6751094ms]: TextMaker_bg.dwr : 160661 bytes : [7.2.2020 3:13.48 GMT]
[6751094ms]: TextMaker_de.dwr : 145512 bytes : [7.2.2020 3:13.34 GMT]
[6751094ms]: TextMaker_dk.dwr : 140559 bytes : [7.2.2020 3:13.44 GMT]
[6751094ms]: TextMaker_ee.dwr : 144443 bytes : [7.2.2020 3:13.44 GMT]
[6751094ms]: TextMaker_es.dwr : 146457 bytes : [7.2.2020 3:13.36 GMT]
[6751094ms]: TextMaker_fi.dwr : 144152 bytes : [7.2.2020 3:13.44 GMT]
[6751094ms]: TextMaker_fr.dwr : 148025 bytes : [7.2.2020 3:13.34 GMT]
[6751094ms]: TextMaker_gr.dwr : 165993 bytes : [7.2.2020 3:13.48 GMT]
[6751094ms]: TextMaker_hu.dwr : 150168 bytes : [7.2.2020 3:13.40 GMT]
[6751094ms]: TextMaker_id.dwr : 141617 bytes : [7.2.2020 3:13.48 GMT]
[6751094ms]: TextMaker_it.dwr : 145488 bytes : [7.2.2020 3:13.42 GMT]
[6751094ms]: TextMaker_jp.dwr : 148376 bytes : [7.2.2020 3:13.42 GMT]
[6751094ms]: TextMaker_kr.dwr : 144747 bytes : [7.2.2020 3:13.42 GMT]
[6751094ms]: TextMaker_kz.dwr : 159500 bytes : [7.2.2020 3:13.38 GMT]
[6751094ms]: TextMaker_lt.dwr : 147010 bytes : [7.2.2020 3:13.46 GMT]
[6751094ms]: TextMaker_lv.dwr : 147465 bytes : [7.2.2020 3:13.46 GMT]
[6751094ms]: TextMaker_nl.dwr : 144369 bytes : [7.2.2020 3:13.46 GMT]
[6751094ms]: TextMaker_pb.dwr : 146951 bytes : [7.2.2020 3:13.36 GMT]
[6751094ms]: TextMaker_pl.dwr : 148318 bytes : [7.2.2020 3:13.38 GMT]
[6751094ms]: TextMaker_pt.dwr : 146878 bytes : [7.2.2020 3:13.36 GMT]
[6751094ms]: TextMaker_ro.dwr : 146111 bytes : [7.2.2020 3:13.40 GMT]
[6751094ms]: TextMaker_ru.dwr : 163360 bytes : [7.2.2020 3:13.38 GMT]
[6751094ms]: TextMaker_se.dwr : 142753 bytes : [7.2.2020 3:13.44 GMT]
[6751094ms]: TextMaker_si.dwr : 145767 bytes : [7.2.2020 3:13.40 GMT]
[6751094ms]: TextMaker_tr.dwr : 146394 bytes : [7.2.2020 3:13.42 GMT]
[6751094ms]: TextMaker_ua.dwr : 160216 bytes : [7.2.2020 3:13.38 GMT]
[6751094ms]: TextMaker_uk.dwr : 139441 bytes : [7.2.2020 3:13.34 GMT]
[6751094ms]: TextMaker_us.dwr : 139312 bytes : [7.2.2020 3:13.32 GMT]
[6751094ms]: TextMaker_zh.dwr : 141004 bytes : [7.2.2020 3:13.42 GMT]
[6751094ms]: Currently running jobs:
[6751094ms]: Executable D:\Program Files (x86)\EitherMouse\EitherMouse.exe
[6751094ms]: Executable D:\Program Files (x86)\SoftMaker FreeOffice 2018\TextMaker.exe
[6751094ms]: Executable C:\Users\Subhasis\AppData\Local\Mailspring\app-1.7.4\mailspring.exe
[6751109ms]: Executable C:\Users\Subhasis\AppData\Local\Mailspring\app-1.7.4\mailspring.exe
[6751109ms]: Executable C:\Users\Subhasis\AppData\Local\Mailspring\app-1.7.4\resources\app.asar.unpacked\mailsync.exe
*** End of startup log ***
*** End of output ***
subhasiscgr
Ok I though it would be a spec sheet of my hardware and OS details. This spec sheet I shared is created by FreeOffice cause I have the full version installed on VM right now. But I assumed VM specs will do you no good so I shared this instead. I will have to reinstall the full version on this machine to give you a proper spec sheet.
Thanks for sharing the files. I have forwarded the details and files to our development team.
subhasiscgr
Here is the sminfo from Textmaker full version as promised:
Code: Select all
Revision: 976
*** File info ***
[C:\Users\Subhasis\Documents\SoftMaker\Settings\tmw18config.ini]
[tmw]
TmpPathGlobal=C:\Users\Subhasis\AppData\Local\Temp\~tmw2\
Win64Info=2018.64.976
Handling=2
FirstLaunch=6
PreviewPos2=380,543,0
Documents=E:\VM_SHARED\
PdfFiles=C:\Users\Subhasis\Documents\SoftMaker\
AsianFonts=1
ArabicSupport=1
TimeFormat=
DateFormat=
SidebarPage=5167
FrameGrid=0
PageBorders=0
LanguageID=2057
FindFileColumns=245; 142; 58; 130; 175
FindFilePos=759,310,0
DefaultFormat=6
SidebarCharstyleShow=1
PreviewPos=659,432,0
HtmlClipPictures=C:\Users\Subhasis\AppData\Local\Temp\~tmw2\17e46ea8.tmp
WinMax=1
WinSize=130,130,1155,655
SidebarPgfstyleShow=1
BkgndCorrection=1
[tmw History]
RecentFilesPinned=0
HistoryFile0=-1,0,E:\VM_SHARED\debug.docx
[Ignore]
Warnings=0
[tmw MRUFontlist]
Fontname0=Times New Roman
[MRULanguages]
LangID1=1033
LangUsage1=4
*** EOF ***
*** Startup log ***
[00047ms]: InitColors
[00047ms]: InitMouseWheel
[00047ms]: StartMain
[00047ms]: comInit: Ole2
[00047ms]: comInit: TmpSystemInit
[00062ms]: RibbonInit
[00062ms]: Dpi info: 96 ; 96 --- 96 ; 96 --- 96 ; 96 ; 96
[00062ms]: Dialog font final metrics info: (12) --- 7 ; 15 --- 7 ; 15
[00062ms]: comInit: CmdLine
[00062ms]: CmdLine <>
[00078ms]: comInit: OleAutomation
[00109ms]: comInit: Address
[00109ms]: comInit: DDE
[00109ms]: comInit: InitCountry
[00109ms]: Country Settings1: ID:1 CP:4e4 Lid:409 Curr:$ CF:0 NF:12 TS:, DS:.
[00109ms]: Country Settings2: MS:2 LS:, Lng:English
[00109ms]: Country Settings Date: DF:3f21 DS:/ DW:,  D1S:  D2S:,
[00109ms]: Country Settings Time: TF:0 TS:: TA:AM TP:PM
[00109ms]: comInit: InitComPrefs
[00109ms]: comInit: Install
[00125ms]: comInit: InitSpellcheck
[00125ms]: comInit: InitAppPrefs
[00125ms]: comInit: Controls
[00172ms]: comInit: Icons
[00172ms]: comInit: Res
[00172ms]: comInit: AppWindows
[00187ms]: comInit: Frame
[00187ms]: comInit: CreateFrameMenus
[00203ms]: comInit: CreateFrameWindow
[00203ms]: CreateWindowExSm <tmwMdiFrame>
[00203ms]: CreateWindowExSm <SMMDICLIENT>
[00203ms]: comInit: CreateFrameStrips
[00218ms]: CreateWindowExSm <SMCTLSTRIP>
[00218ms]: CreateWindowExSm <SM_SLIDERCTRL>
[00218ms]: CreateWindowExSm <SMCOMBOLB>
[00265ms]: CreateWindowExSm <SMCTLSTRIP>
[00281ms]: CreateWindowExSm <SMCTLSTRIP>
[00281ms]: CreateWindowExSm <SMCOMBOLB>
[00297ms]: CreateWindowExSm <SMCTLSTRIP>
[00312ms]: CreateWindowExSm <SMCTLSTRIP>
[00328ms]: CreateWindowExSm <SMCTLSTRIP>
[00343ms]: CreateWindowExSm <SMCTLSTRIP>
[00359ms]: CreateWindowExSm <SMCTLSTRIP>
[00406ms]: CreateWindowExSm <SMCTLSTRIP>
[00406ms]: CreateWindowExSm <SMCOMBOLB>
[00468ms]: CreateWindowExSm <SMCTLSTRIP>
[00484ms]: CreateWindowExSm <SMCTLSTRIP>
[00500ms]: CreateWindowExSm <SMCOMBOLB>
[00500ms]: CreateWindowExSm <SMCTLSTRIP>
[00515ms]: CreateWindowExSm <SMCTLSTRIP>
[00547ms]: CreateWindowExSm <SMCTLSTRIP>
[00562ms]: CreateWindowExSm <SMCTLSTRIP>
[00562ms]: CreateWindowExSm <SM_SLIDERCTRL>
[00578ms]: CreateWindowExSm <SM_SLIDERCTRL>
[00578ms]: CreateWindowExSm <SMCTLSTRIP>
[00578ms]: CreateWindowExSm <SMCOMBOLB>
[00593ms]: CreateWindowExSm <SMCTLSTRIP>
[00593ms]: CreateWindowExSm <SMCOMBOLB>
[00609ms]: CreateWindowExSm <SMTOOLTIP>
[00609ms]: comInit: Colors
[00609ms]: comInit: ThemeSelect
[00609ms]: comInit: WindowSize
[00625ms]: CreateWindowExSm <SMRIBBONHEADER>
[00625ms]: CreateWindowExSm <SMDOCTABS>
[00625ms]: comInit: Treeview
[00625ms]: comInit: Cursors
[00640ms]: comInit: AppBrushes
[00656ms]: comInit: AppFormat
[00656ms]: comInit: AppIcons
[00656ms]: comInit: AppBuffer
[00656ms]: comInit: BrushCache
[00656ms]: comInit: AppFonts
[00656ms]: comInit: AppLFile
[00687ms]: comInit: Accelerators
[00687ms]: comInit: History
[00687ms]: comInit: appData
[00687ms]: spInitCountryInfo(0): ID:1 Date:DMYhmsQ TS:, DS:.
[00687ms]: spInitCountryInfo(1): ID:1 Date:DMYhmsQ TS:, DS:.
[00703ms]: GetMRULanguages
[00703ms]: comInit: Printer
[00859ms]: comInit: QuickPath
[00859ms]: comInit: MAPI
[00859ms]: comInit: Speller
[00859ms]: comInit: Register
[01000ms]: comInit: ddeCmdList Start
[01000ms]: comInit: ddeCmdList End
[01000ms]: comInit: ShowWindow
[01000ms]: comInit: Timer
[01000ms]: comInit: appCmdList (non-null) Start
[01000ms]: comInit: appCmdList (non-null) End
[01000ms]: comInit: AutoLoad
[01000ms]: comInit: appCmdList (null) Start
[01000ms]: comInit: appOpenCommandList
[01047ms]: CreateWindowExSm <WP>
[01047ms]: CreateWindowExSm <WPCHILD>
[01062ms]: CreateWindowExSm <SMRULER>
[01062ms]: CreateWindowExSm <SMRTAB>
[01062ms]: CreateWindowExSm <SMVRULER>
[01062ms]: CreateWindowExSm <SCROLLBAR>
[01062ms]: CreateWindowExSm <SMSCROLLBAR>
[01062ms]: CreateWindowExSm <SMVERTBUTTONS>
[01062ms]: CreateWindowExSm <AWERESIZER>
[01062ms]: CreateWindowExSm <SIDEWND>
[01187ms]: CreateWindowExSm <UNICONTROL>
[01187ms]: CreateWindowExSm <SM_SEPARATOR>
[01203ms]: CreateWindowExSm <SM_OUTSCROLLAREA>
[01203ms]: CreateWindowExSm <SM_INSCROLLAREA>
[01203ms]: CreateWindowExSm <SM_SCROLLAREABUTTON>
[01203ms]: CreateWindowExSm <SM_HLINK>
[01203ms]: CreateWindowExSm <UNICONTROL>
[01203ms]: CreateWindowExSm <SM_BUTTON>
[01218ms]: CreateWindowExSm <SM_CHKBOX>
[01218ms]: CreateWindowExSm <SM_HLINK>
[01218ms]: CreateWindowExSm <SM_COMBOLIST>
[01234ms]: CreateWindowExSm <UNICONTROL>
[01250ms]: CreateWindowExSm <SMSCROLLBAR>
[01375ms]: LoadDocument <->
[01672ms]: CreateWindowExSm <SM_SLIDERCTRL>
[01687ms]: CreateWindowExSm <SM_SLIDERCTRL>
[01703ms]: CreateWindowExSm <SM_SLIDERCTRL>
[01765ms]: CreateWindowExSm <UNICONTROL>
[01765ms]: CreateWindowExSm <SMSCROLLBAR>
[02047ms]: LoadDocument End
[02062ms]: comInit: appCmdList (null) End
[02062ms]: comInit: Address
[02062ms]: comInit: UpdateCheck
[02062ms]: System information startup log finished.
[02062ms]: comInit: Dispatch
[77406ms]: Delayed AppData
[77406ms]: ===============
[77406ms]: Date 07.04.2020, 18:16
[77406ms]: Windows 10.0, Build 18363 720
[77406ms]: TextMaker 2018, Revision 976.0313 (64 Bit)
[77406ms]:
[77406ms]: Windows: C:\WINDOWS\system32 (33696 MBytes free)
[77406ms]: Tempfiles: C:\Users\Subhasis\AppData\Local\Temp\ (33696 MBytes free)
[77406ms]: TEMP: C:\Users\Subhasis\AppData\Local\Temp
[77406ms]: TMP: C:\Users\Subhasis\AppData\Local\Temp
[77406ms]: Application: D:\Program Files\SoftMaker Office 2018\TextMaker.exe (14944 MBytes free)
[77406ms]: License: C:\ProgramData\SoftMaker\of2018.lic 1720 bytes
[77406ms]: Memory: 29/100 of 3613804 MBytes used
[77406ms]: Screensize 1366x768
[77406ms]: Printers:
[77406ms]: Windows printer <SEC30CDA7ABCBED,winspool,Ne00:>
[77406ms]: Printer <SEC30CDA7ABCBED,Samsung M267x 287x Series,http://192.168.1.211:8018/wsd>
[77406ms]: Printer <OneNote,Microsoft Software Printer Driver,>
[77406ms]: Printer <Microsoft XPS Document Writer,Microsoft XPS Document Writer v4,>
[77406ms]: Printer <Foxit Reader PDF Printer,Foxit Reader PDF Printer Driver,>
[77406ms]: Printer <FlexiPDF,ActMask,>
[77406ms]: Printer <Fax,Microsoft Shared Fax Driver,>
[77406ms]:
[77406ms]: Resource files:
[77406ms]: TextMaker_ar.dwr : 163170 bytes : [13.3.2020 2:8.20 GMT]
[77406ms]: TextMaker_bg.dwr : 170475 bytes : [13.3.2020 2:8.20 GMT]
[77406ms]: TextMaker_de.dwr : 154416 bytes : [13.3.2020 2:8.14 GMT]
[77406ms]: TextMaker_dk.dwr : 148982 bytes : [13.3.2020 2:8.18 GMT]
[77406ms]: TextMaker_ee.dwr : 153550 bytes : [13.3.2020 2:8.18 GMT]
[77406ms]: TextMaker_es.dwr : 155459 bytes : [13.3.2020 2:8.14 GMT]
[77406ms]: TextMaker_fi.dwr : 152314 bytes : [13.3.2020 2:8.18 GMT]
[77406ms]: TextMaker_fr.dwr : 157441 bytes : [13.3.2020 2:8.14 GMT]
[77406ms]: TextMaker_gr.dwr : 176469 bytes : [13.3.2020 2:8.20 GMT]
[77406ms]: TextMaker_hu.dwr : 159506 bytes : [13.3.2020 2:8.16 GMT]
[77406ms]: TextMaker_id.dwr : 150165 bytes : [13.3.2020 2:8.20 GMT]
[77406ms]: TextMaker_it.dwr : 154371 bytes : [13.3.2020 2:8.18 GMT]
[77406ms]: TextMaker_jp.dwr : 156966 bytes : [13.3.2020 2:8.18 GMT]
[77406ms]: TextMaker_kr.dwr : 153234 bytes : [13.3.2020 2:8.18 GMT]
[77406ms]: TextMaker_kz.dwr : 169309 bytes : [13.3.2020 2:8.16 GMT]
[77406ms]: TextMaker_lt.dwr : 155671 bytes : [13.3.2020 2:8.20 GMT]
[77406ms]: TextMaker_lv.dwr : 156866 bytes : [13.3.2020 2:8.20 GMT]
[77406ms]: TextMaker_nl.dwr : 153307 bytes : [13.3.2020 2:8.20 GMT]
[77406ms]: TextMaker_pb.dwr : 156051 bytes : [13.3.2020 2:8.14 GMT]
[77406ms]: TextMaker_pl.dwr : 157444 bytes : [13.3.2020 2:8.16 GMT]
[77406ms]: TextMaker_pt.dwr : 155841 bytes : [13.3.2020 2:8.14 GMT]
[77406ms]: TextMaker_ro.dwr : 155188 bytes : [13.3.2020 2:8.16 GMT]
[77406ms]: TextMaker_ru.dwr : 173498 bytes : [13.3.2020 2:8.16 GMT]
[77406ms]: TextMaker_se.dwr : 151343 bytes : [13.3.2020 2:8.18 GMT]
[77406ms]: TextMaker_si.dwr : 155129 bytes : [13.3.2020 2:8.16 GMT]
[77406ms]: TextMaker_tr.dwr : 155191 bytes : [13.3.2020 2:8.18 GMT]
[77406ms]: TextMaker_ua.dwr : 170302 bytes : [13.3.2020 2:8.16 GMT]
[77406ms]: TextMaker_uk.dwr : 148022 bytes : [13.3.2020 2:8.14 GMT]
[77406ms]: TextMaker_us.dwr : 147895 bytes : [13.3.2020 2:8.14 GMT]
[77406ms]: TextMaker_zh.dwr : 149488 bytes : [13.3.2020 2:8.16 GMT]
[77406ms]: Currently running jobs:
[77406ms]: Executable C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
[77406ms]: Executable C:\WINDOWS\system32\sihost.exe
[77422ms]: Executable C:\WINDOWS\system32\svchost.exe
[77422ms]: Executable C:\WINDOWS\system32\taskhostw.exe
[77422ms]: Executable C:\WINDOWS\Explorer.EXE
[77422ms]: Executable C:\Program Files\Tablet\Wacom\Wacom_TabletUser.exe
[77422ms]: Executable C:\WINDOWS\system32\igfxEM.exe
[77422ms]: Executable C:\WINDOWS\system32\igfxHK.exe
[77422ms]: Executable C:\WINDOWS\system32\SettingSyncHost.exe
[77422ms]: Executable C:\WINDOWS\SystemApps\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy\StartMenuExperienceHost.exe
[77422ms]: Executable C:\Windows\System32\RuntimeBroker.exe
[77422ms]: Executable C:\WINDOWS\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe
[77437ms]: Executable C:\Program Files\WindowsApps\Microsoft.YourPhone_1.20022.82.0_x64__8wekyb3d8bbwe\YourPhone.exe
[77437ms]: Executable C:\Windows\System32\RuntimeBroker.exe
[77437ms]: Executable C:\Program Files\Google\Drive\googledrivesync.exe
[77437ms]: Executable C:\WINDOWS\system32\DllHost.exe
[77437ms]: Executable C:\Program Files\Screenovate\Virtoo\VirtooClient.exe
[77437ms]: Executable C:\Program Files\Mullvad VPN\Mullvad VPN.exe
[77437ms]: Executable C:\WINDOWS\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exe
[77437ms]: Executable D:\Program Files (x86)\EitherMouse\EitherMouse.exe
[77437ms]: Executable C:\Users\Subhasis\AppData\Local\Temp\a4fd432b-f1d2-467f-bb7e-24fda79ae5f4\WinDbg.exe
[77437ms]: Executable C:\WINDOWS\system32\conhost.exe
[77437ms]: Executable C:\Users\Subhasis\AppData\Local\Temp\a4fd432b-f1d2-467f-bb7e-24fda79ae5f4\idaq.exe
[77437ms]: Executable C:\Users\Subhasis\AppData\Local\Temp\a4fd432b-f1d2-467f-bb7e-24fda79ae5f4\wireshark.exe
[77437ms]: Executable C:\Users\Subhasis\AppData\Local\Temp\a4fd432b-f1d2-467f-bb7e-24fda79ae5f4\vmacthlp.exe
[77437ms]: Executable C:\Users\Subhasis\AppData\Local\Temp\a4fd432b-f1d2-467f-bb7e-24fda79ae5f4\VBoxService.exe
[77437ms]: Executable C:\Users\Subhasis\AppData\Local\Temp\a4fd432b-f1d2-467f-bb7e-24fda79ae5f4\VBoxTray.exe
[77437ms]: Executable C:\Users\Subhasis\AppData\Local\Temp\a4fd432b-f1d2-467f-bb7e-24fda79ae5f4\procmon.exe
[77437ms]: Executable C:\Users\Subhasis\AppData\Local\Temp\a4fd432b-f1d2-467f-bb7e-24fda79ae5f4\ollydbg.exe
[77437ms]: Executable C:\Users\Subhasis\AppData\Local\Temp\a4fd432b-f1d2-467f-bb7e-24fda79ae5f4\vmware-tray.exe
[77437ms]: Executable C:\Users\Subhasis\AppData\Local\Temp\a4fd432b-f1d2-467f-bb7e-24fda79ae5f4\idag.exe
[77437ms]: Executable C:\Users\Subhasis\AppData\Local\Temp\a4fd432b-f1d2-467f-bb7e-24fda79ae5f4\ImmunityDebugger.exe
[77437ms]: Executable C:\WINDOWS\system32\ApplicationFrameHost.exe
[77453ms]: Executable C:\Program Files\WindowsApps\Microsoft.WindowsStore_12003.1001.1.0_x64__8wekyb3d8bbwe\WinStore.App.exe
[77453ms]: Executable C:\Windows\System32\RuntimeBroker.exe
[77453ms]: Executable C:\WINDOWS\system32\svchost.exe
[77453ms]: Executable D:\Program Files\SoftMaker Office 2018\TextMaker.exe
[77453ms]: Executable C:\WINDOWS\system32\backgroundTaskHost.exe
[77453ms]: Executable C:\WINDOWS\system32\SearchProtocolHost.exe
[77453ms]: Executable C:\Program Files\WindowsApps\Microsoft.YourPhone_1.20022.82.0_x64__8wekyb3d8bbwe\YourPhoneServer\YourPhoneServer.exe
I converted all autoshapes into textbox. It did not improve anything.
Thanks for sharing this sminfo. Please also send us your Settings folder for Softmaker for both the versions. You can find it in My Documents\SoftMaker folder. Please zip this settings folder and send it to us so that we can analyze your SoftMaker Office Settings.
subhasiscgr
Doing that is proving hard. For some reason WinRar can not read the files even in admin mode (I also tried taking an ISO. Same access Denied Error). Yet administrators have read access to that folder and all of it is inherited.
There is nothing special in that folder though. To make sure, I uninstalled Softmaker Office, deleted that entire folder, reinstalled Softmaker office again. Then I did the same with FreeOffice. Still, if you want it, I will need to prepare a Linux boot drive.. or I will guidance on how to backup that folder from within Windows.
As you mentioned that you completely reinstalled FreeOffice, did you completely reinstall SoftMaker Office Pro also in which you are getting this problem of slow performance?
Please try to send this folder from the installation of SoftMaker Office Pro, it actually contains all the software settings which our development team can analyze.
subhasiscgr
Yes. I installed both versions from scratch after deleting that folder each time.
I will try to get that folder.
subhasiscgr
SuperTech wrote: Fri Apr 10, 2020 8:41 pm As you mentioned that you completely reinstalled FreeOffice, did you completely reinstall SoftMaker Office Pro also in which you are getting this problem of slow performance?
Hi,
I have been very busy during the quarantine. I could not get the time to reinstall everything. But now I have better. I am facing the same issue in 2021 beta. Here is the folder. But I could not read tmpstart.dad even with system account.
Hope it will help.
Edit: It is the same folder for both versions... right? (C:\Users\Subhasiscgr\Documents\SoftMaker\Settings)
Settings.rar
Softmaker Settings file.
(73.75 KiB) Downloaded 3060 times
Thanks for sharing the folder which I have forwarded to our development team for analysis.
We have analyzed the settings and found that you are using SoftMaker Office 2021 and not SoftMaker Office 2018. TextMaker 2021(64bit) is a little slower than TextMaker Free 2018 (32bit) because of additional advanced features and difference in architecture (64/32 bit). And in your settings by default, the thumbnail view and the paragraph styles are enabled which consume additional resources and take some time in refreshing.
1. Thumbnail view update itself when you add/delete text so it consumes additional resources and takes some additional time, but in rev.1020 it is improved than previous revision, so please update your SoftMaker Office 2021.
2. 64-bit version can be slower than 32 bit.
3. TextMaker 2021 has a lot of additional features that might slow down TextMaker 2021 compared to TextMaker Free 2018.
Performance should already be better in rev.1020, but the thumbnail view may still make TextMaker 2021 slower than TextMaker 2018, since thumbnails did not exist there.
