1. I could not import the attached file, as it is, as one with fixed field widths, because the import facililty decided that the second field began in the last column - so the most significant digits for numbers more than 9 got appended to the first field!
2. Rather than just fixing this problem, it would be better to have some method of indicating or specifying the field widths.
Problem importing text file with fixed field widths
nicholassmall
Post by nicholassmall »
- Dedicationsx.txt
- (2.01 KiB) Downloaded 5617 times
Re: Problem importing text file with fixed field widths
Unfortunately, there's nothing we can do at the moment since your file doesn't have columns with an exact width. I'll forward this issue to the product manager
- SoftMaker Office 2021
