Font equivalents
Post your questions, bug reports and suggestions here for SoftMaker fonts.
Font equivalents
Is there a tabulation of the fonts available in the Megafont collection showing what "big name" commercial fonts each most closely corresponds with? Such a list would make font selection much easier for those of us who read articles on font selection by professional graphic designers, who use the font names they know from the major type houses.
For example: Is Palazzo a version of Palatino?
How close is Uncial to American Uncial?
Re: Font equivalents
There's no such list, sorry
How about creating one?
I own a copy of MegaFonts. I'm a hopeful, would-be author and that means I don't have an agent or a big publisher behind me. If I get a book finished and I want to publish it, it will have to be either self-published ("vanity press"), or print-on-demand. That means I am responsible for the book design, the typesetting ... everything. The problem is that when I read articles in the Internet regarding what fonts the professionals prefer or recommend for body test when typesetting a book, they use the names of professional fonts from the "big name" type houses. Since I'll be using fonts from the MegaFonts collection, it would be very helpful to know which of your fonts match (or most closely approximate) those big name fonts.
I'll report the issue to the product manager. Thank you for your feedback!
lgsl
Post by lgsl »
Woody44 wrote: Tue Feb 18, 2020 1:41 am For example: Is Palazzo a version of Palatino?
Not really. Palatino have different metrics to Palazzo. While the letters look almost identical, Palazzo is not truly an equivalent/replacement for Palatino.
It may work just fine for a new design (There are a few things to keep in mind: due a difference in metrics, the readability may vary. Maybe is a great font for paragraphs, maybe is not), but in an existing design that uses Palatino, replacing the font with Palazzo could cause issues due the differences in metrics (for instance: things may not align correctly).
V_Sirin
Post by V_Sirin »
Woody44 wrote: Tue Feb 18, 2020 10:55 pm How about creating one?
Hi Woody. Much like you, I have books to be self-publishing and I wanted a good font. So I bought "Equity" by Matthew Butterick. I also highly recommend his site "Practical Typography". Also, the Fontbase program says it has a font analysis tool that would help compare fonts, but does cost a monthly subscription, which you could then cancel once you've identified which fonts you want to use.
Hope this helps.
lgsl wrote: Wed Mar 04, 2020 8:08 pm
When you come right down to it, even fonts carrying the same name don't share the same metrics. I have compared, for example, several versions of Baskerville (from various sources) and they are VERY different. I just went through the same thing with two versions of Caslon (again, same name but from different sources). With the Caslons, I had to increase one of them to 13.5 point in order to match the spacing and size of the other in 12 point. It's an issue -- the proliferation of Truetype and Opentype fonts has made point size into a joke.
Post by Jossi »
Anybody creating a new font can name it as he likes (as long as he doesn't violate copyright for an existing font). Especially "classical" fonts like Baskerville, Caslon or Garamond have been recut, digitized or re-interpreted so many times by different type designers and companies that there is absolutely no guarantee that any font bearing such a name has any similarity in metrics or font size with another one bearing the same or a similar name.
Rodi
Post by Rodi »
Woody44,
I hope all is well with you.
I am a life longer lover and user of fonts.
I have used very expensive fonts (Berthold Diatronic, Linotype 202, 202N, L300) and some very inexpensive fonts.
The softmaker Library is a combination of classic fonts and some interesting historical fonts.
I use a host of fonts professionally (as a graphic artist).
Any good and proper page layout program will make your type look even. Pick the right fonts for the job and it will look fine.
There is no hard and fast rules on actual text fonts, but use a classic. For the cover you can be more generous
https://luc.devroye.org/SM-FONTS.PDF
sergiuvolda
Post by sergiuvolda »
Woody44 wrote: Tue Feb 18, 2020 1:41 am Is there a tabulation of the fonts available in the Megafont collection showing what "big name" commercial fonts each most closely corresponds with?
Do you mean a font that is metric-compatible, or just a font that looks similar?
Fedora Linux Workstation 41. Former Manjaro and Ubuntu user.
sergiuvolda wrote: Thu Jul 03, 2025 2:02 pm
Preferably look-alikes that are metrics-compatible but, considering that many fonts sharing the same name (from different sources) are metrics-compatible, I'll settle for visual look-alikes.
Return to “SoftMaker Fonts”
