Cannot print landscape
mariosk
Post by mariosk »
Hello,
I try to print landscape but it is not possible really.
I have noticed that from Payout > page orientation when i choose landscape the margins look as if had chosen portrait and vice versa. Is there a bug? I am missing something?
No matter what i do, both from layout and from preferences in the print pop up window, it only prints portrait.
Please help
Re: Cannot print landscape
1. Layout | Define Print range
2. Layout | Page orientation | Landscape
3. File | Print Preview . You'll see a preview of a sheet of paper landscape
wcj
Post by wcj »
No, it will simply not print a spreadsheet in landscape. Set to landscape in either Printing Presets or under Settings: the Show Settings says Landscape, the Preview displays in Portrait and the print comes out in portrait.
Please share your sminfo file which you can generate by clicking on '?' > About > Write system information.
Also, please make a screen recording for better understanding of this problem which you can create with any free tool like www.screentogif.com
Spood
Post by Spood »
Hi
This appears to be identical to the issue I am experiencing on Linux - Different OS but the printing issue is the same
https://forum.softmaker.com/viewtopic.php?f=392&t=20942
