I've been using PlanMaker this morning and I noticed that it was almost too easy to drag and drop cells, when all I needed to do was select a contiguous group of cells with a left mouse click and drag (like Excel).
Is there any setting to adjust the time you hold the mouse button before the little selection square appears, to avoid the cell being dragged unnecessarily? (It was easy to undo, of course.)
(But PlanMaker makes for a pleasant change from Excel so far.
Thanks for your help
