AutoFill List Error
RDMcDivit08
AutoFill List Error
Post by RDMcDivit08 »
I receive this error when I open PlanMaker 2018.
"Unable to load AutoFill List"
It happened with the free version as well.
Clip of the error window attached.
Re: AutoFill List Error
Could you please uninstall and reinstall the software?
RDMcDivit08
Thanks.
I tried that but still get the error.
It's a Mac book pro.
Could you please go to "? | About | Write System Information" and send us the sminfo.txt file it generates? You may post it here or send it to forum(at)softmaker.de
RDMcDivit08
Sorry, I don't understand your request.
Is it a command entered within Planmaker or is it from the Terminal App?
In PlanMaker, at the top right corner you'll find a question mark "?".
RDMcDivit08
Thanks.
Here's the sminfo file.
sminfo.txt
(290.43 KiB) Downloaded 6039 times
Thanks. I'll let you know when the developers answer to my support request.
RDMcDivit08
Great.
Thanks for the quick response.
In the settings folder, there should be a pmfill.dat, this is the file that contains user-defined lists and seems to be scrambled.
Please send me that file (post it here or send it to forum(at)softmaker.de
Afterward, delete the file and the error message will go away.
RDMcDivit08
Here is the zipped pmfill.dat file.
Yes, that fixed the error.
Thanks.
pmfill.dat.zip
(996 Bytes) Downloaded 5822 times
The issue has been fixed and the fix it will be included in our next service pack to be released in the next few days.
Return to “PlanMaker 2018 for Mac”
