Repo update issue
sidhymes@gmail.com
Repo update issue
Post by sidhymes@gmail.com »
Hello,
I've been receiving the the following message when attempting to update the suite: "cannot update repo 'SoftMaker_Office_Repository': repomd.xml GPG signature verification error: Bad GPG signature". This started about 10 days or so ago. I'm using Fedora 30 x64.
I'm not clear if just downloading another version of the public key will solve the issue and I haven't found anything online addressing it. Suggestions/recommendations?
Thanks.
Michael Uplawski
Re: Repo update issue
Post by Michael Uplawski »
sidhymes@gmail.com wrote: Thu Jan 09, 2020 6:59 pmI'm not clear if just downloading another version of the public key will solve the issue and I haven't found anything online addressing it. Suggestions/recommendations?
You did not say much about how you set up your package management system. In consequence, and even if you know it already, I recommend the section about Fedora on the “Tips and tricks” - page, set up by SoftMaker: https://www.softmaker.com/en/tips-linux. The part about updating the public key presents the command
Code: Select all
sudo rpm --import linux-repo-public.key
, which you do know already or not...
The key, you get from https://shop.softmaker.com/repo/linux-repo-public.key
In case that these explanations do not help you, come back again.
There are flatworlders all around the globe. (unknown author)
If we go now, nature may stand a chance. (known author)
