Hi
I recently upgraded to a HD 4k monitor (3840 x 2160) and am looking for ways to improve the layout of Textmaker/Planmaker. as the fonts etc., are too small. If anyone has the same issue I'd welcome some advise.
Thank You
Upgraded to 4k Monitor
- Contact:
Re: Upgraded to 4k Monitor
What user interface scaling have you set in Windows?
If you still have the problem, please send us a screenshot of TextMaker right next to another program that displays in a way you like.
Hi
As suggested I enclose a couple of screenshots I took recently.
Thanks.
Thanks.
Thank you for your screenshots. May I bother you just a little more by asking you to go to the top right corner of your screen, then click on the "?" icon | About | Write System information and send us the sminfo.txt file it generates? You can post it here or send it to forum(at)softmaker.de.
As requested see attached file.
- sminfo.txt
- (29.09 KiB) Downloaded 5452 times
According to your sminfo.txt file, you are running Ashampoo Office 2018 revision 944.
The latest version of SoftMaker Office 2018 is rev.972.
Could you please try to install our trial version and see if the scroll bars are still thin?
https://www.softmaker.com/en/softmaker-office-download
