Missing Line in The Dialog Function , Help File
enonod
Post by enonod »
For the benefit of anybody who has tried the complex Dialog Function example and failed...
In the Help File (and possibly the Manual) there is an example of one dialog opening a second.
It is under the Heading "The Dialog Function". It does not work as shown, however if the following line is added...
DlgVisible "History"
In Case 2 beneath DlgVisible "Chk2" as shown below, then it will work.
Code: Select all
    Case 2
        If ControlID$ = "Chk1" Then
                               DlgEnable "Group"
                               DlgVisible "Chk2"
			       [b][i]DlgVisible "History"[/i][/b]
        End If
Return to “BasicMaker 2018 for Windows”
