Please explain this weirdo
enonod
Post by enonod »
Stepping through the following code below in the Editor...
It works perfectly, failing each 'If' condition correctly... UNTIL you remove the 'Rem' on 'Do While' and 'Loop'. Then the final 'ElseIf' passes when it should fail, but note that both sets of code are identical.
I have simplified my code so as to eliminate anything to do with the spreadsheet that might have confused, or suggest it is the spreadsheet causing the problem.
This appears to be some kind of bug but I cannot get around it. Any ideas?
Code: Select all
Sub Update()
	Dim count As Integer, a As Integer, b As Integer
   	count = 3 :	a=4 : b=0
Rem	Do While count > 0
		count = count -1
		If a = 6 Then
			b=6
			a=3
		ElseIf a = 6 Then
			a=4
		End If
		If a = 6 Then
			b=6
			a=3
		ElseIf a = 6 Then
			a=4
		End If
Rem	Loop
End Sub
CWM
Re: Please explain this weirdo
Post by CWM »
Your code works fine (with or without the loop) the oddity looks like it is in the way BM steps through the lines. Even though it shows as if it is on the last line of the ElseIf statement, it does not execute it.
enonod
Post by enonod »
Thank you CWM and sorry for the delay, I have been indisposed.
Return to “BasicMaker 2018 for Windows”
