Am I thick?
enonod
Am I thick?
Post by enonod »
I am desperately trying to construct a date...
I have all the preliminaries regarding the pm Object inside each main (saving space here).
Taken from the help file but All Result in: Error in line: 2 - Type mismatch
sub Main
print DateSerial(2018,09,25)
end sub
Sub Main
Print DateValue("Sep 25, 2018")
End Sub
Sub Main
MsgBox Format(Date,"dd.mm.yyyy")
End Sub
Sub Main
pm.Range("L1").Value = Format(Date,"dd.mm.yyyy")
End Sub
Re: Am I thick?
Thanks for reporting this problem. I ran these codes and there is no error found. Please share the associated file of PlanMaker 2021 and Script in which you are getting this problem so that we can do further investigation for resolution.
https://forum.softmaker.com/viewtopic.p ... 673#p63918
Return to “BasicMaker 2018 for Windows”
