Text(a1, "mmm") not in Basicmaker
enonod
Post by enonod »
Text(a1, "mmm") in a cell correctly converts the date's month 11 to Nov.
EntryMonth = pm.activesheet.Text(pm.activesheet.Range("LastUpdate").Value, "mmm")
results in...
Object doesn't support this property or method
Have I done wrong or is it not supported?
Re: Text(a1, "mmm") not in Basicmaker
You can't use PlanMaker calculation functions in BasicMaker scripts (you can use them in a cell and read the result from BasicMaker).
What you are looking for is the BasicMaker function "Format".
enonod
Post by enonod »
Thank you for your useful guidance martin-k.
I am actually surprised, in VBA (which I know is not Basicmaker) the following is the full item...
EntryMonth = WorksheetFunction.Text(pm.activesheet.Range("LastUpdate"), "mmm")
which I guess means you do not have the equivalent of "WorksheetFunction".
Yes, this is correct.
enonod
Post by enonod »
Whilst I have you, If I may be so bold, may I ask why the following does not work.
a1 is a date and date formatted.
pm.activesheet.Range(a1).Value = pm.activesheet.Range(a1).Value +1
to simply add one day.
You need to put "a1" in quotes. It is a string that represents a cell name.
enonod
Post by enonod »
I am sorry matin-k I was generalising by using a1 the actual is...
pm.activesheet.Range("LastUpdate").Value = pm.activesheet.Range("LastUpdate").Value + 1
where LastUpdate is A1 named.
edit: what happens is that it changes 26/11/2019 to 26/01/1900
Return to “BasicMaker 2018 for Windows”
