Hello,
I'm trying to create a table of contents in my document. The problem is that the one that gets created is not active, I mean, I can't click a page to go to it automatically. How can I do that?
Another question is, can I convert the first word of a paragraph into a title? As I see, it takes automatically the whole paragraph as the title, so when I create the table of contents, it takes all the paragraphs.
Thank you.
Active table of contents
Re: Active table of contents
The first item has not been implemented the last time I checked. This functionality has been requested. Maybe the next version?
Use the Document map. View->Sidebar
The advantage over the contents page is that it's always present.
- Contact:
We are planning clickable tables of contents for the next version.
