I've read some other posts on the forums about this, but there weren't any solutions.
My wife is using Free Office on a MAC, and I am using it on a Win10 laptop. Both machines have respectable specifications, so it's not a matter of the machines being slow. We aren't seeing this behavior with other applications (from other vendors) on the same machines.
Autosave is turned on, and for a good 15-30 seconds when it's saving, the application freezes and you are unable to do anything. I understand you can turn autosave off, but it's a feature I would like to take advantage of.
My sminfo.txt is attached.
Saving is slooooooooow
david.hoffman
- sminfo.txt
- (11.87 KiB) Downloaded 3522 times
Re: Saving is slooooooooow
1. Does it happen with all files and only one? Please attach the file or send it to forum(at)softmaker.de
2. Where are you saving the files to?
3. Does textMaker Crash? If so, please send us the Documents\tmlog.txt file.
I've been having the same issue.
1. All files.
2. I'm saving it to my SSD (default folder in Documents)
3. Textmaker does not crash, but if I'm typing when it happens, it seems to treat all my inputted characters as commands (commands vs input as in ctrl+c instead of c, except I don't think it is a straight change)
Edit:
Also, a potentially related issue: https://forum.softmaker.com/viewtopic.php?f=298&t=19272
When it autosaves, specifically if you are typing while it does so, it tends to cause the program to sort of flicker. Not sure if this happens when not typing.
1. All files.
Edit:
Could you please send us one of such files? Post it here or send it to forum(at)softmaker.de.
I happens in both Mac and Windows?
If it only happens in Windows, could you please disable your antivirus temporarily to check if it's the culprit?
