When converting to HTML format in an html file, instead of text, strings with decimal codes are obtained.
Example:
Original file
<p> To help you find information, the flow of chapters goes from more general usage information to more specific help and usage information. </ p
Target file
<p >
Чтобыпомочь вам в поискеинформации,
потокглав.......
Can this problem be solved?
Decimal codes instead of text
1 post
- SoftMaker Office 2021
