Excel text/column issue
EricC
Post by EricC »
Hello,
I have PM set to use XLSX as the default file format.
Steps to reproduce:
1. Type: "Some really long text to test out column auto width"
2. Right click the column and select Autofit Width so there is no text spilling over into column B.
3. Save the spreadsheet.
If I open the sample file below in Excel (from Office 365) the text spills over into column B. I can reproduce this issue with other spreadsheets.
Thanks,
-Eric
PlanMaker 2018 r970
test.xlsx
(5.81 KiB) Downloaded 4991 times
Re: Excel text/column issue
Hi, I reported the issue to the developers. Thank you for your feedback!
