I was writing a document and while exiting Textmaker I accidentally clicked on "no" when the pop up asked me if I want to save the changes..
can I recover it?
I tried looking for backups but I couldn't find it
yes I have "Auto-Recovery" and "Create backup files" checked in the "Options" menu but I am unable to locate the backup(if there is any)
what should I do in this case?
OS- Windows 10
Textmaker 2018
pl help me with this issue
thank you
Accidently clicked on dont save while exiting Textmaker
- Contact:
Re: Accidently clicked on dont save while exiting Textmaker
Unfortunately, when you tell it not to save, then it really does not save. You can go to Documents\SoftMaker\Backup to find older versions of the file.
- SoftMaker Office 2021
