Internal Error ERR-206-5
Hi! I created a portable installation of my Softmaker Office 2018 to a VeraCrypt encrypted usb drive. When I've started TextMaker, I got the "internal error ERR-206-5" message as displayed on the attached screenshot. What to do now? Thanks in advance: C.
Re: Internal Error ERR-206-5
Hi, it's possible that VeraCrypt uses some sort of intermediate container for storage that's causing the issue. I'd advise you to investigate if other VeraCrypt users are experiencing similar permission errors with other software.
Also, try to right-click TextMaker.exe and run as administrator.
Thanks, Miguel, running as administrator helped - and since then it works flawlessly with normal user privileges too.miguel-c wrote: ↑Fri Nov 01, 2019 7:21 pm Hi, it's possible that VeraCrypt uses some sort of intermediate container for storage that's causing the issue. I'd advise you to investigate if other VeraCrypt users are experiencing similar permission errors with other software.
