[Solved]USB stick file removals
Princy557
Post by Princy557 »
HI
When creating a usb copy to work a way with I notice ALL the files transfer over, Including I think all the language files.
For space on the USB stick reasons, Can I delete any files and only leave the English one ?
Please advise thoughts ideas on that one? is there a shortcut batch or something to do it.?
Regards
Princy557
Re: USB stick file removals
Yes, you can delete all *.dwr files except for *_uk.dwr. You have to do that manually though.
Princy557
Post by Princy557 »
(we could do with a button on this site for [Resolved])??
I'll have a look at the deletions later today.
Regards
Princy557
You can edit your original post and prepend "[Solved]" to the subject line.
Princy557
Re: [Solved]USB stick file removals
Post by Princy557 »
Thanks,
Regards
Regards
Princy557
Princy557
[Resurrected] USB stick file removals
Post by Princy557 »
Thoughts occur.
Wanted to double check with a few other things....
How about the .rtf's such as license-xx.rtf ??? Keeping only the -uk ones in my case
html_xx folders.
I assume they can all go as well.
Nice clean out if it can and obviously works for each individual country.
Regards
Princy557
Yes.
