_GoBack bookmark
_GoBack bookmark
Hello,
It wasn't working correctly so I deleted if and now I don't know how to get it back.
Anyone know how to get the _GoBack bookmark to work again? (I tried but it has to start with a letter.)
Thanks!
Thanks!
Re: _GoBack bookmark
Hi, you could reset your TextMaker settings by closing TextMaker and then going to Windows Explorer and renaming the file Documents\SoftMaker\Settings\tmw18config.ini to tmw18config.bak.
- Contact:
_GoBack is an internal bookmark that you don't set manually. It is created automatically when "Return to the last editing position when a document has been opened" in Files | Options | Files is activated and the document is saved.
Hey miguel-c,
I did what you asked but I only saw ‘tmwfo18config’. I changed the name of that to .bak but it did not restore the _GoBack bookmark.
Am I mistaken to assume that that bookback feature returns the READER back to their previous position? Martin-k’s comment makes it seem like this is more of an EDITTING tool.
Yes: that feature returns the READER back to their previous position.
PS: if you wish you may make a backup copy of your Documents\SoftMaker\Settings\ folder and then delete it in order to reset your SoftMaker Office to its default settings.
Thanks for your reply.
If I start a new document, that _GoBack bookmark returns.
Still wondering if there is a way to re-insert it into a document after it has been deleted.
I'm going to ask a colleague of mine. In the meanwhile, you may create a new document and copy the content from the other file into the new one
I tried that. All 40+ pages of content that I then had to reformat to get the spacing 100% like it was. Not to mention, the bookmarks were also copied and the "_GoBack" one missing.
- Contact:
You don't create the _GoBack bookmark by hand. It is created automatically at the current cursor position when you save a document and have the option "Return to the last editing position when a document has been opened" in the Options dialog, Files tab active.
I just activated this, made an edit and saved the document. I closed it and reopened it and still no _GoBack.martin-k wrote: ↑Fri Nov 01, 2019 8:07 pm You don't create the _GoBack bookmark by hand. It is created automatically at the current cursor position when you save a document and have the option "Return to the last editing position when a document has been opened" in the Options dialog, Files tab active.
- Contact:
We support that only in DOCX and TMDX formats. Which format did you use?
Hi, I was able to reproduce the issue where I don't see the _GoBack bookmark in newly created documents.
I'm going to report this to the developers and I'll let you know when we sort this out.
Thank you!
Thank you!
