[SOLVED] Error opening sheet with graphics made with PlanMaker LINUX in Windows Excel
PRafael
Post by PRafael »
Hi.
I'm working with PlanMaker Linux on a Brasilian Ubuntu based distro with last version and patches of Plan Maker Linux (Office 2018). I made some graphics in it and when I open the file in Windows Excel (version 2013), it gives the following errors (files attached) and wipes out all the graphics.
Please, feel free to ask if this isn't self explained. I'll try later to send a picture with the graphics
Edited: If I save the file as XLS the graphics are preserved and I can open them in Excel.
Regards
Paulo
Matriz de Documentos e sua Importância - TRABALHO.xlsx
(12.8 KiB) Downloaded 5624 times
Re: Error opening sheet with graphics made with PlanMaker LINUX in Windows Excel
Hi, I opened the file you sent us in Excel (Windows) and PlanMaker (Ubuntu) and I didn't receive any warnings.
I also wasn't able to see any charts or drawings... Could you please send us the file with the issues?
Thanks,
PRafael
Post by PRafael »
Hi miguel-c.
Thank you for your replay. Attached you will find the file.
Regards
Paulo Rafael
(167.5 KiB) Downloaded 5814 times
Hi, on my Excel 2019 I get a warning: "You’ll get a warning: The reference is not valid. References for titles, values, sizes, or data labels must be a single cell, row, or column."
However, the graphics are displayed.
PRafael
Post by PRafael »
Thank you miguel-c for your information.
However as stated in the post I'm working with Excel 2013 and not Excel 2019. So, the problem remains...
Because I'm using a paid version, I should ask...what softmaker will do regarding the resolution of this issue?
Regards
Paulo Rafael
On the 'Graficos' sheet the third chart, starting at A45, edit the 'certificados' series has the source area ='Resumo Perguntas'!$J$2:$AO$11.
When we changed the reference to ='Resumo Perguntas'!$J$2:$J$11 then Excel doesn't complain about this chart any more.
PRafael
Post by PRafael »
Just to say that you can close and mark solved this thread.
The solution...just enter zeros (0) when you don't have any data on the graphic.
Ragards
Paulo Rafael
Return to “PlanMaker 2018 for Linux”
