After entering text in a cell and pressing the TAB key, the highlighted cell correctly moves, but if additional character keys or arrow are pressed, they are ignored. If either the Space-bar or the Return key is pressed, the "Add/Remove Buttons" menu pops down. This menu is normally shown after pressing the two right-facing carats ">>" to the right of the formula bar.
I've repeated this problem with both .xlsx and .pmdx version of new files.
sminfo.txt file is attached.
Moving horizontally using TAB key locks up the keybrd
kstambaughAZ
Post by kstambaughAZ »
- sminfo.txt
- (300.4 KiB) Downloaded 5085 times
Return to “PlanMaker 2018 for Mac”
- SoftMaker Office 2021
