Hi,
So I am playing around with PlanMaker and PowerShell. I am basing some of this code off code I have from a PowerShell script to enumerate AD groups and populate an Excel spreadsheet. Starting small, I thought I would create the spreadsheet and autofit the column.
$groupName = 'somereallylongname'
$row = 1
$column = 1
$pmSpreadsheet = New-Object -ComObject PlanMaker.Application
$pmSpreadsheet.Visible = $True
$workbook = $pmSpreadsheet.Workbooks.Add()
$worksheet = $workbook.ActiveSheet
$worksheet.Cells.Item($row, $column).Value = $groupName
$worksheet.Range("A:B").AutoFit
If run the above code in a PowerShell console everything works up until the AutoFit. Which throws the following message:
OverloadDefinitions
void AutoFit ()
I converted the code to BasicScript, ran it in the BasicScript editor, and everything works as expected.
Any ideas?
Thanks,
-Eric
W10 1903 x64
SMO2018 x64 Rev970
1 post
- SoftMaker Office 2021
