Remove #N/A
Princy557
Remove #N/A
Post by Princy557 »
HI,
how to remove the #N/A from a cell with this in it. (While it's empty)
=IF(LEN(VLOOKUP($C$6,'Customer List'!$A$2:$K$25,2,0))=0,"",VLOOKUP($C$6,'Customer List'!$A$2:$K$25,2,0))
Regards
Princy557 :?
Regards
Princy557
Re: Remove #N/A
Hi, you could use the IFERROR function to replace #N/A by something of your choosing.
Example:
=IFERROR(VLOOKUP($C$6,'Customer List'!$A$2:$K$25,2,0),"message")
Princy557
Re: Remove #N/A
Post by Princy557 »
Hi miguel-c
Works a treat thanks for the quick response.
Regards Princy 557
Regards
Princy557
