Greetings,
i am looking into being able to export my presentation for handouts. However, it seems that presentations always downsizes text regardless of number of slides per page, or whether i export a pdf. In effect, the text size is so small that it's impossible to read... Is there a workaround for this?
Thanks in advance
Exporting to pdf makes slides tiny
Re: Exporting to pdf makes slides tiny
Hi, could you please:
1. send us a sample Presentations file
2. send us the PDF file
3. tell us the steps you did.
Thanks for your reply, where do i send the files?
You may post them here or send them to forum(at)softmaker.de
