Hello
Is there a way to search for specific strings of text inside Textmaker files in my home directory?
I can save them as .rtf files, and do a search with grep, but it can't "see" into .tmdx files.
Searching for text inside TMDX files
Re: Searching for text inside TMDX files
TMDX and DOCX files are zip files, so if you find a way to search inside zip files in linux, that will work.
I found this site that may be a good starting point:
https://unix.stackexchange.com/question ... -zip-files
- Michael Uplawski
Miguel got it entirely right.., then withdrew from the affair, leaving you in an awful mess to sort out on your own...
I feel with both of you.
So, as could be derived from the referenced discussion, you have to unzip the tmdx-file. Do this in a folder that you can remove afterwards, or directly in the /tmp directory of your system.
Unfortunately, though, the unzipped tmdx-file contains sub-directories and the text of your document is only found in the file word/document.xml. You should write a shell-script which takes this into account.
Not enough.
TextMaker compresses the document.xml (and other xml-files) in the way, that line-breaks are removed. To read and interpret XML, those are not necessary and would just bloat up the file (Side-note: In OTF, they would be mortal as TextMaker mis-interprets them). Ergo, you have to beautify the xml-code before you can search it. If you skip this step, every key-word searched for will result in the entire XML-structure being returned, as your document.xml is a one-liner !!!
Good luck.
I am sarcastic, if that escaped you.
My recommendation would be, to use, in fact, an xml-parser on document.xml. Explaining the use of such software is off-topic in this discussion, the result will satisfy the OP, however.
Not enough.
Good luck.
“Hindsight is in the eye of the beholder.”
And not that knowledgeable about Linux, it would appear. Fortunately, miguel-c gave me a good starting point.
The answer is to use zgrep from zutils. It is not the same zgrep that comes by default in Debian, which is just a shell script and can't do recursive searches through files in a directory. I can search by typing this into a terminal:
Code: Select all
zgrep 'search term' -r /path/to/documents
- Michael Uplawski
zgrep is not Linux, it is zgrep.
Very nice, thank you for sharing your solution!colonel_panic wrote: ↑Tue Oct 08, 2019 10:16 amAnd not that knowledgeable about Linux, it would appear. Fortunately, miguel-c gave me a good starting point.
The answer is to use zgrep from zutils. It is not the same zgrep that comes by default in Debian, which is just a shell script and can't do recursive searches through files in a directory. I can search by typing this into a terminal:Code: Select all
zgrep 'search term' -r --format=gz /path/to/documents
I put a little typo into my example above. Please find it corrected below:
Code: Select all
