I have my presentation format set to On Screen 16:9
I have some images that I want to fill each slide. They are saved in a16:9 ration size (e.g. 1280 x 720px), but when I insert a picture frame, the image distorts. It fills the slide vertically but only partially fills the slide horizontally.
If I double click on the image to bring up the properties, I can see that Presentations has scaled the image - but not proportionally - horizontal scaling is 40% and vertical scaling is 45% - even though the image started off in the right ratio and the 'keep aspect ratio' box is ticked
In the end I managed to get the image right by amending its dimensions in cm manually, but this took a lot of fiddling and I shouldn't have to do this.
Why is an image in 16:9 ratio not displaying at that ratio in a 16:9 presentation?
Problem Inserting Picture Frame
Return to “Presentations 2018 for Windows”
- SoftMaker Office 2021
- FreeOffice 2021
