How to set number of lines and more?
Paultx
Post by Paultx »
I need to set a certain document pages so they all have:
- 30 lines
- 70 characters per line
I went to File > Page setup but found nothing there to make these settings.
I used the ruler slider to set the number of characters per line and to set the number of lines I selected a paragraph and went to Format > Paragraph to try different paragraph spacings until I got the right setting to have the 30 lines in an acceptable appearence.
Is there a way to set all that automatically in TextMaker 2018? TIA.
Desktop PC: Windows 10 Pro - 64-bit • Intel Core i7 • 12 GB RAM
Laptop PC: Windows 10 Pro - 64-bit • Intel Core i5 • 6 GB RAM
Re: How to set number of lines and more?
Hello, not that I know of...
In the meanwhile I found this article that may be useful to you:
https://smallbusiness.chron.com/limit-c ... 75318.html
