Templates
whatgives?
Templates
Post by whatgives? »
Is it possible to use format templates for headings, bullet point lists, and regular text? I can't seem to find a function for that, and after the latest update the text in my presentation has been transformed to different color/size etc... It would be convenient to apply a general format instead of going through each slide, if possible. Thanks in advance!
Re: Templates
Hi, you could use the Slide Master feature to to create a master slide that servers as template for the other slides in the presentation.
This option is available in View | Slide master
Return to “Presentations 2018 for Windows”
