Wildcards within formulars
Babylonia
Post by Babylonia »
Hello,
I am just trying to make some kind of "IF" / THAN" formula to add in my worksheet.
But don't get the right wildcard functionality.
E.g. a simple comparison.
I have a column with "text" attributes as for telephone numbers:
Within a cell I do want the outcome to be "Mobile" or "Landline" as for the comparison of the first two digits.
(Mobile numbers in Holland always do start with 06 and do have 10 digits without the international number format).
Formulas are translated by me, as I am using a Dutch version of Planmaker, and formulas do have Dutch attributes.
By HELP file the wildcards should be written as "^?" for each character (a strange wildcard interpretation IMO).
or "*" for many numbers.
E.g. used "mobile" numbers:
0612345678
0687654321
0633333333
Formula that should do the trick ?? (C3 = the cell containing the number):
=IF(C3="06^?^?^?^?^?^?^?^?";"Mobile";"Landline")
or a more logical wildcard interpretation
=IF(C3="06????????";"Mobile";"Landline")
or at least
=IF(C3="06*";"Mobile";"Landline")
ALL of these formulas do give "Landline" as outcome.
However if I change e.g. the formula to:
=IF(C3="0612345678";"Mobile";"Landline") ----> the outcome is "Mobile"
So what is the correct wildcard interpretation?
Babylonia
Re: Wildcards within formulars
Post by Babylonia »
Nobody have an answer or solution??
Hi, =IF(LEFT(A1;2)="06";"Mobile"; "Landline") will do what you want.
Babylonia
Post by Babylonia »
Thank you. That did the trick.
