Today I installed the newest version (SoftMaker Office Pro 2018) and there was no horizontal ruler on TextMaker. (There was such a ruler at the top of the page, by default in my older version, TextMaker 2016.) I have looked in the PDF manual; and it simply states that the horizontal ruler is at the top of the page. NOT ON MY Page.
How can I active it to be there?
THANK YOU.
Where is horizontal ruler
- Contact:
Re: Where is horizontal ruler
The ruler is on by default, so it seems you have turned it off by accident. View | Ruler will turn it on again.
Ernie Berger
Martin-K,
THANK YOU very much. Your suggestion solved the problem. So, perhaps I did accidently turn it off.
Again, thank you.
Ernie
Again, thank you.
Ernie
