Links and paragraph formatting problem?
jamesd1
Post by jamesd1 »
When I paste a link in to Texmaker and then press return to enter some text below that link, Texmaker uses the formatting of the link in the next line which is not what a writer would want. You then have to reformat the paragraph before you can continue. How to avoid this problem. I'ts a pain.
Re: Links and paragraph formatting problem?
Post by Jossi »
Hi, I tried to reproduce this problem but couldn't. When I copy a link address from my browser (Firefox) and paste it into a TextMaker document, the link is in blue and underlined, but otherwise it has the same font and size as my previous text, and following text is unchanged. Where do you get the links from? Which browser and which version of TextMaker? Is "Format URLs as hyperlinks" checked in Tools > Options, tab "Edit"? Did you try to paste the links unformatted (with Shift+Ctrl+V instead of Ctrl+V)?
Hi, I also wasn't able to reproduce the issue too with the latest official version: 966.0704
