PlanMaker 2018 freezes when save a sheet
When I modify a sheet and then save the file PlanMaker freezes and it takes several minutes to go back to work. I never have this problem in SoftMaker products. I am using Windows 8.1. TextMaker works fine saving a file. I purchase the update yesterday and the first 3 or 4 times I used it worked well.
Re: PlanMaker 2018 freezes when save a sheet
Hi, could you please send us the PlanMaker file that is causing the issue? If you don't feel comfortable posting it here, please send it to forum (at) softmaker.de
Sorry for the delay, I've been very busy with personal things.
First PlanMaker created a file 8 times larger than the original size and now it does it well and without problems, it does not freeze and the size is normal. I do not understand, the program had never done something like this to me, maybe the last update corrected the problem. In any case, thanks for the attention paid to my problem.
