Merge questions
Jon Polish
Merge questions
Post by Jon Polish »
I need to produce a report of a dbf within a larger document. In other word processors there is an option "Next Record." This allows multiple records to appear in the same document. I cannot find this option in TextMaker.
A related question. Can I use two or more databases in different areas of a document or is it limited to one database per document? I suspect the former and have used workarounds that are cumbersome.
Thank you.
Jon
Re: Merge questions
1. Maybe with List/Label you'll be able to achieve what you want.
2. It's not possible to have 2 databases per document.
Jon Polish
Re: Merge questions
Thank you Miguel.
Jon
