Hello,
I'm new to planmaker. I really like it but I noticed a problem which I'm facing when opening .xlsx files in planmaker in Linux.
The file and all the formulas were made at work on Windows (excel) computer.
After I open it in planmaker all looks ok, until I save the file and reopen.
The conditional formatting changes and shows wrong icons in the cells. The green check should be where value is zero but it is now where value is negative, the exclamation mark should be where value is greater but it's at where value is zero and cross should be where value is negative but now it shows where value is greater.
I have attached two photos.
Of course I can change it back everytime by opening conditional formatting, but thats not really what I want to do each time I work from my home computer which runs linux.
Just wondering if anyone had similar problem and if there's a solution or other way to do it, to keep the colors, icons the way I have them now.
Thank you
Conditional formating changes when saved and reopened
- Contact:
Re: Conditional formating changes when saved and reopened
Upload the file before and after, and we will have a look.
Hi,
Attached are the "before" and "after" files.
Thank you
Thank you
- After1.xlsx
- (10.52 KiB) Downloaded 5786 times
- Before.xlsx
- (17.54 KiB) Downloaded 5597 times
Hi, I was able to reproduce the issue you reported and I'm going to report it to the developers.
This issue was fixed and the fix will be included in the next service pack
