KDE integration
gannicus
KDE integration
Post by gannicus »
Is it possible to configure softmaker to use KDE's save dialogs?
Re: KDE integration
That's not possible. In order to access KDE functionality, we would need to turn SoftMaker Office into a Qt application.
AndresCodex
Re: KDE integration
Post by AndresCodex »
martin-k wrote: Sat May 25, 2019 9:25 pm That's not possible. In order to access KDE functionality, we would need to turn SoftMaker Office into a Qt application.
Thanks for replying, but that is not correct:
KDE allows to use it's dialog without the need of a Qt application.
The implementation is very easy:
First we check if KDE dialog is found '/usr/bin/kdialog'
If this is found we will call it = 'kdialog --getsavefilename /home/.cach-file-directory.doc'
This is too easy to implement. 8)
euphonious81
Re: KDE integration
Post by euphonious81 »
I found the file /usr/bin/kdialog. Can you provide further clarification on the next step? Are we modifying this file or do we create a new file or do we add an argument for when we start the application? Thank you!
