How to see two worksheets of the same document at the same file
Simon
Post by Simon »
Hi,
I want to know how to see worksheet1 on the left and worsheet2 on the right if both are in the same document.
I just can see document 1 and document 2, as always, now with the chance to open each in their own window. However, what I need is to make this with the worksheets in a file, as OpenOffice has been able at least for TEN YEARS!
Than you
Re: How to see two worksheets of the same document at the same file
Hi, PlanMaker doesn't have that functionality.
I'll forward this to the developers for analysis.
Thank you for your feedback!
Princy557
Post by Princy557 »
Hi
Does View | Windows | Side by side work
Regards Princy557
Regards
Princy557
Post by Jossi »
Princy557 wrote: Sat Sep 07, 2019 10:41 am Hi
Regards Princy557
Doesn't this imply that PlanMaker would have to open an already opened document a second time? I don't think this will work.
Princy557
Post by Princy557 »
duplicate the working file as filename_copy
Open them both.
I am making the assumption that only one file will be changed (the master)??
It was just a though that might have worked.
Regards
Princy557
Post by Jossi »
Yes, this works, but the two files will not be synchronized. So one of them should be read-only.
Princy557
Post by Princy557 »
HI Jossi,
Did not realize he wanted to synchronize the files just to look at them.
Regards
Princy557
