Accented characters
G.R.H
Accented characters
Post by G.R.H »
Is it possible to enable the selection of accented characters by holding down the character key and have the selection show up as per other programs on a Mac? As I use accented characters a lot this would be great to have. Thanks.
G.R.H
Re: Accented characters
Post by G.R.H »
I appreciate that I have put this in the wrong section (Windows) - sorry, perhaps you can move it please.
Hi, thank you for your suggestion. I'm going to forward it to the developers for evaluation.
JezShed
Post by JezShed »
If you hold a character key down then doesn't that simply cause the keyboard auto-repeat to kick in? It does on all the programs I've ever used.
The only time I see extra character options pop up is if I'm using my Android phone.
Be interested to know if the Mac has a different way of providing special characters compared to Windows.
In windows I tend to use the ALT-gr key with the vowel key for the accute accent (é). Otherwise I use the character map program, and sometimes I use ALT-xxxx with the numeric keypad to bring up a special unicode character such as ALT-0177 for the ± charecter for example.
Sometimes I seriously condiser a dedicated French keyboard for the times I work on French documents :)
My normal keyboard is UK.
Jez
I finally moved this to the Mac forum, where it belongs.
Yes, this is macOS-specific behavior (similar to mobile phones) that we don't have yet.
Bill
Post by Bill »
I have just downloaded Free Office and discovered that the Mac accent functionality (that I use a LOT) does not work. It would be great if that could be integrated [-o<
Return to “SoftMaker Office 2018 for Mac (General)”
