Textmaker Trial 2018 962.0418 64 bit
MacPro mid 2010 - High Sierra
Hi,
I saw advertised that there was now scanner support for dropping pictures directly into a Textmaker page.
Under the 'Picture icon I only have 'From file' and a check box for inserting as a frame.
Is this function not available in the trial? If so, what is the point of having a trial if you can't use it to its full extent?
Thanks in advance.
Aquire picture from scanner
- Contact:
Re: Aquire picture from scanner
This feature is only available in the Windows version. On other operating systems, you can scan with your scanner's application and insert the scan as a file.
