Hello,
I would like to have a negative number appear in RED text.
I have found that I can use conditional formatting to change the cell shading but have not found a way to conditionally format text color.
Is there any way to do this?
Thank you!
Conditional Formatting TEXT?
- Contact:
Re: Conditional Formatting TEXT?
There is a much easier way than conditional formatting. Just press Format > Cell or Ctrl+1, select one of the numeric types and choose "Display negative numbers in red". Alternatively, you could choose a custom formatting string (described in the manual).
WOW - that was simple!!!
Thank you so much
Thank you so much
