Feature request
Feature request
It would be very useful to have an adjustable print area and the option to fit into one or more sheets
Re: Feature request
I will refer your suggestion to the product management.
Re: Feature request
Before I open this CD to install, does it have a resume template.
- Contact:
Re: Feature request
Yes. You can also open any Word resume templates that you find on the internet.
Re: Feature request
Thanks for speedy reply.
