opening file as readonly, no promt
jfe
Post by jfe »
Many times I open a docx , pptx file from an email or website. Since those files are not saved properly they are write only. Due to that I receive a prompt asking it ok to open as read only. I am of course okay with that as my alternative is to have the file be closed. Is there a way to disable the prompt as there is no situation where I would choose no?
Re: opening file as readonly, no promt
Post by sven-l »
Are you opening the files from an network folder or directly from an e-mail? It seems that you have no write permissions on the folder where your files are.
Michael Uplawski
Post by Michael Uplawski »
I am helping.
The OP asked
jfe
Post by jfe »
Michael Uplawski wrote: Wed Apr 17, 2019 1:59 pm I am helping.
Thank you for your help
Why don't check the checkbox "Do not show this message again"?
jfe
Post by jfe »
I cannot see the checkbox in this prompt. Where is the checkbox located?
Hi, I'm going to suggest a "Do not show this message again" checkbox to the product management. Let's see if they agree :)
jfe
Post by jfe »
thanks
