Sending mails via TextMaker reading info from PlanMaker
ignacio.busquets
Post by ignacio.busquets »
Does anyone knows if it's possible to send multiple mails via TextMaker reading the information from PlanMaker.
There is a feature to send mails in TextMaker but reading a database made in TextMaker not from an archive in PlanMaker.
If possible which mail software has to be used?
Re: Sending mails via TextMaker reading info from PlanMaker
Post by sven-l »
There can only be one single e-mail created at once when you use the mail send feature from TextMaker or PlanMaker.
You can create mail-merges in Thunderbird with this add-on:
https://addons.thunderbird.net/de/thund ... ail-merge/
